Dale flowers
- Oct 14, 2021
- 5
- 1
Hi every one, I wonder if any body can help me (because the fiat dealers want£!!!!!!!!!!! just to look at it and God knows how much to fix it :bang. I am the proud owner of a 2017 1.6 Doblo with the tyre pressure monitoring unavailable notice stuck on. this problem started about 3 months ago and I presumed that a tyre sensor had failed, I didn't like the Cargo Marathon s that were on it so I Bit the bullet and had new tyres and sensors fitted, I then followed the procedure for resetting/reprogramming them to to the tpms module/ecu several attempts and over a hundred miles later it's just the same. After several sessions on the Multiecuscan I've come to the conclusion that the tpms module/ecu is at fault, the trouble is I can't find it on the car and fiat won't tell me where it is. Many thanks in advance and any advice or solution will be much appreciated. This is my third Doblo after a 2004 and a 2009 again many thanks. Dale
