jamesdavies
- Apr 15, 2021
- 2
- 1
Hi All,
I have just removed an aftermarket UHF radio from my 2003 2.8 JTD Ducato motorhome. I haven't intentionally disturbed/disconnected any factory wiring, but when I tried to start the car, There was no go. I checked there was fuel at the injectors, leaving just injector enabling. Sure enough they're not firing. I purchased a VAG-COM cable and used MultiECUScan to see there is an active U1600 Fault. It is interesting that the Padlock symbol is not illuminated. It doesn't even flash on. I've never noticed if it did in the past.
- Both Keys give the same error code, It happened suddenly, suggesting FOB's are ok.
- Immobiliser Antenna is OK (~40 Ohm)
- I have tried disconnecting the battery several times, from a few seconds to 2 hours.
- Is there a way to see what keys are programmed, I'm wondering if the immobilizer has lost it's memory?
- I have downloaded the eLearn program, but finding the electrical schematics I'm after is a pain. Any ideas what wire signals the ECU the key is ok, I've checked all the fuses and terminals I can find. and the plugs on the Immobilizer module.
I'm 500km from the nearest Dealer, so getting the vehicle to a dealership isn't really an option.
:bang::bang::bang:
:bang::bang::bang:
