robbocop33
- May 5, 2021
- 8
- 3
Haven't found my specific problem on here.All right indicators don't work,fault code b1007 direction lamp incorrect?
Hazard light switch doesn't operate right indicators,neither does the indicator stalk.I've replaced all bulbs to rule that out.Indicator light on dash flashes quickly when right indicators selected.
At the front right indicator bulb i used a power probe and applied 12v to the bulb,it lit,which rules out the bulb and proves the earth is good.
I'd love to know which pink wire coming out of the bcm is the right indicators one.I'm expecting my test light to flash off and on when i find it,all pink wires i've tested at the bcm have showed a 'constant' 12v and not going on and off with the indicator pulse??Couple other pink wires didn't show a voltage at bcm,but as i said,i don't know which pink wire is one i'm after.
Just had a thought,the rear driver side light cluster has the long brass coloured threaded bolt broken off,please dont tell me this is the earth for the cluster?Or is it just to help mounting the cluster?
