500 Help with radio code 2010 fiat 500
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Bessboo06
Hi , I had a new stereo as old one broke and I have code but I can’t for the life of me put the code in . I go to button 1 for first number and hold it down to get to the number I need and it does nothing. If I try to tap the number 1 button to get to the number I need then if fills with 1111 and blocks me for 30 mins . Helllllp please
It’s the original radio for car .
From the Fiat 500 radio handbook:
When the radio is switched on, if the secret
code is requested, the display will
show the wording “Code” for about 2 seconds
followed by four dashes “- - - -”.
The secret code is made up of four digits
from 1 to 6, each corresponding to one of
the dashes.
To enter the first digit of the code, press
the button corresponding to the pre-selection
stations (from 1 to 6). Enter the
other code digits in the same way.
If the four digits are not entered within
20 seconds, the display shows the wording
“Enter code - - - -”. If this occurs, it is
not considered an incorrect code entry.
After entering the fourth digit (within
20 seconds), the car radio starts to work.
If an incorrect code is entered, the radio
will emit a sound and the display shows the
wording “Radio blocked/wait” to notify
the user of the need to enter the correct
code.
Each time the user enters an incorrect
code, the waiting time gradually increases
(1 min, 2 min, 4 min, 8 min, 16 min, 30 min,
1h, 2h, 4h, 8h, 16h, 24h) to a maximum of
24 hours. The waiting time will be shown
on the display with the wording “Radio
blocked/wait”. After the wording has disappeared
it is possible to start the code
entering procedure again.
I can’t get it up to 8 which is my first number , the number 1 comes up but if I hold it , it does not increase number , I bought radio off eBay . Has he given me wrong code ?
Thanx everyone , I’ve blocked it so going to have to leave ignition on tomorrow for as long as it takes , I’ve bought correct code now .
I never asked forum for code , I thought I had one from seller but it blocked radio and that was where I asked help with . I just went ahead and purchased correct code.
hello,i need code for fiat 500 radio model 2019
i need code radio for fiat 500 model 2019 serial number is 03330 FCA PN:07357227250 continental flat 312 7
