Bravo bleed screw for the coolant has broken
melee
hi
i am new to this
what i need to help with is i have a fiat bravo 2008 & the bleed screw for the coolant has broken off what's the best way to get it out to replace it or tighten it up to stop it leaking ?
any help would be great
thanks
hi
i am new to this
thanks
The head carries an o.ring
No head : no seal
Use a drill in reverse to wind out the screw
I believe it is just an M6 thread..
So a bolt with a broad head..and tranferred o.ring should work
do you knows how long the bolt should be ? does it need to be plastic ?
ive messed it up cant get the screw out do you know what the pipe is called what the bleed screw in on looks like i need to replace that
Post a picture please then we may know .
here is a picture
off a FIAT BRAVO SPORT M-JET 150
2008
coolant bleed screw
It may be
FIAT 51795046 Hose, heat exchange heating
Search images yourself to make sure.
It will be expensive from fiat.
If you can gently cut the retaining collars off the plastic vent part save the rubber hoses . fit another vent part cut from an easily obtainable cheaper fiat hose (500 / panda) . Fit to your hoses using hose clips.
As your hose is now off the car ( and indoors..)
Get a hex screwdriver bit..
Hold it securely in mole grips..
Then hold it in a flame ( gas hob..) for a few seconds.. it will soon get HOT
THEN hold the blade end up against the broken screw..
'Branding 'a new slot in the screw
After a minute of so.. you should be able to unscrew the broken part
Thank you very much for all the help you have given
I ended up doing as advised by yourself & I am going to adapt the engine coolant hose
thanks again
