![]() | #1 | ||
Posts: 6 Thanks: 1 Trader Rating: 0 ![]() | electric heated windscreen failure Hi Fellow Fiatsters I have a 2016 4x4 Panda Cross bought it used it had the winter pack but within a year the heated windscreen on the drivers side started to break down any one with any idea where i could get it replaced. don't think its repairable as the connections are hidden under the screen. cheers Fiatsters ![]()
![]() | #2 | ||
![]() | Re: electric heated windscreen failure
![]() | #3 | ||
Posts: 27,218 Thanks: 1050 Trader Rating: 0 ![]() | Re: electric heated windscreen failure Welecome ![]() @food for thought There is a thread about this that pops back into view as the weather turns frosty ![]() https://www.fiatforum.com/panda-iii/429677-heated-screen.html?429677=#post4106943 https://www.fiatforum.com/panda-iii/484260-my-heated-screen-damaged-faulty.html?484260=#post4567719
![]() | #4 |
Posts: 2,668 Thanks: 227 Trader Rating: 0 ![]() | Re: electric heated windscreen failure I'd have thought it's not worth replacing the screen just for the sake of the heating function, assuming you're out of warranty. I'd wait until you get a bad enough stone chip to justify a new screen on your car insurance. It's only a matter of time...
__________________ Barchetta LE (no 2468), 1998, Silver with Red Hood/Leather, Hardtop, Wind-stop, Novitec SS Exhaust Panda Cross Twinair, 15 Reg, in glorious Yellow ![]() Talbot-Matra Murena 2.2 (Prep 142), 1983, Aquamarine Last edited by gar074; 5 Days Ago at 09:53. |
![]() | #5 |
Posts: 2,640 Thanks: 379 Trader Rating: 0 ![]() | Re: electric heated windscreen failure The connectors can be reached, by removing the plastic panel between the base of the screen and the bonnet. But that won't help. The wires in the screen are hair-thin, and at the bottom edge of the screen appear as four pieces of thin 'plastic foil' which the connector plugs are moulded onto. I think the issue is that these bend and flex, and eventually the wires inside break.
__________________ 2018 Panda 4x4 MJ :: North Herts :: Remember, if you find a post helpful, press the Thumbs up 'thanks' button below |
![]() | thewoods | 500L | 3 | 13-01-2019 17:27 |
![]() | NitramA | 500X | 15 | 05-12-2016 14:32 |
![]() | 4WDPandamonium | Panda (Classic) | 8 | 03-06-2015 22:36 |
![]() | angtho | Panda (2012+) | 3 | 23-09-2014 23:23 |
![]() | John Knight | Bravo / Brava | 1 | 23-05-2011 20:04 |
