Georgesbigshed
- Oct 15, 2020
- 7
- 3
Hi and hello. My little Doblo 2007 1.9jtd 8 valve is in disgrace arrived home from the motorway via AA recovery truck. Cut out dead no sputtering jus immediate dead.
Morning after released fuel filter bleed screw cranked and it fired up down the road and back parked up all running fine. 4 hours later no start so let’s sort this.
Tank pump out check pump filter, apply 12v to pump working.
Brown wire earth connected continuous Blue white no live when ignition on
Check fuse and relay both ok. Bridge 30 and 87 fuel pumping Try to start won’t fire.
Where to next does the tank pump run continuously or just to prime high pressure pump? Is the ECU in control of this process?
Cheers.
Cheers.
