![]() | #1 | ||
Posts: 13 Thanks: 0 Trader Rating: 0 ![]() | Newbie alert Hello all. New to the forum having just purchased a 500s in Electroclash Grey and black wheels. It’s my wife’s car and she loves it. There are a few niggles I want to sort out. Blue and me socket broken, eBay second hand item on its way. Old one soaked in coffee. Not a great location for a drink holder right next to an electrical item. Fuel cap strap crumbled away. New one In the post. Rear seat backs badly scratched, might remove and respray. What is the best ODB scanner. I have a Carly but not used it yet. Thanks for reading.
![]() | #2 | ||
Posts: 35 Thanks: 3 Trader Rating: 0 ![]() | Re: Newbie alert My daughters fuel cap strap has broken (the loop at the end). Can you tell me where you got a replacement. I couldn't work out where it was attached either. Thanks
![]() | #3 | ||
Posts: 13 Thanks: 0 Trader Rating: 0 ![]() | Re: Newbie alert Hi I bought the replacement by just typing it in to google, was about £20 if I remember. The barrel needs removing as per another members post, very useful. The other end of the strap is located inside the filler flap on the hinge. The second hand Bluetooth & me socket charges for a second and stops. Must be a loose connection or a dried out joint inside the unit. Fuse is ok as the thing lights up at night.
![]() | #4 | ||
Posts: 3,826 Thanks: 166 Trader Rating: 0 ![]() | Note this picture on how to hang fuel cap when filling(usually not done hence why its snapped left dangling scratching the paintwork?), blue and me can give issues mostly flattern the battery, suggest disconnecting the unit behind the rear passenger quarter panel, replacing the radio with aftermarket, re reader, you need a laptop and MES fiat software about £80 including the leads and download
![]() | #5 | ||
Posts: 35 Thanks: 3 Trader Rating: 0 ![]() | Re: Newbie alert Note this picture on how to hang fuel cap when filling(usually not done hence why its snapped left dangling scratching the paintwork?), blue and me can give issues mostly flattern the battery, suggest disconnecting the unit behind the rear passenger quarter panel, replacing the radio with aftermarket, re reader, you need a laptop and MES fiat software about £80 including the leads and download
![]() | #6 | ||
Posts: 3,126 Thanks: 285 Trader Rating: 0 ![]() | Re: Newbie alert As John says above your best bet is the Multiecuscan (MES) software. I think most of us run it on windows laptops but I believe there are other options. You can download the software and run it in simulate mode to get a good idea of what it can do - and it can do a lot! Much, much more than you're average cheap OBD scanner. There are several options for connecting to the vehicle. If you look on the forum main menu there is a section dedicated to it where you can access the MES website - or click this link: https://www.multiecuscan.net/ If you want to ask questions there are a lot of us on here who use it so just ask away. Also very useful are the people at Gendan: https://www.gendan.co.uk/product_FESPKG.html Which is where I bought mine from. They are very helpful and used to answering "daft" questions. I know, I asked just about every daft question in the book before I bought. After sales support is excellent too. I would also advise you against buying cheap interfaces on line. I've read many posts on here from people detailing how much trouble they've had with them.
![]() | #7 | ||
Posts: 13 Thanks: 0 Trader Rating: 0 ![]() | Re: Newbie alert Many thanks for the replies. I will read up on the multiscan items. Does it only run on a windows 7 laptop as I will have to get one. Going back to blue and me, does the usb socket only work ie (charge) once selected on steering wheel src button Many thanks
![]() | #8 | ||
Posts: 3,126 Thanks: 285 Trader Rating: 0 ![]() | Re: Newbie alert I can't tell you about the USB socket because I've never tried using it!
![]() | #9 | ||
Posts: 1,235 Thanks: 89 Trader Rating: 0 ![]() | Re: Newbie alert The USB socket should charge whenever the ignition is on. I don't use it for such, having a flash drive with all my music more or less permanently fitted, but I understand it's pretty low-powered and unsuitable for many modern phones and tablets and the like.
![]() | #10 | ||
Posts: 13 Thanks: 0 Trader Rating: 0 ![]() | Re: Newbie alert Low power might explain it. Thanks
![]() | #11 | ||
Posts: 1,235 Thanks: 89 Trader Rating: 0 ![]() | Re: Newbie alert There are any number of adapters out there that plug into the CL socket and supply more power. I use one with two CL and three USB sockets to power my dashcams and so on. It slots neatly into the compartment ahead of the cup holders.
![]() | #12 | ||
Posts: 3,689 Thanks: 281 Trader Rating: 0 ![]() | Re: Newbie alert Also has a tablet/phone usb version.
![]() | #13 | ||
Posts: 3,826 Thanks: 166 Trader Rating: 0 ![]() | We have this, next to the power socket, cost £4 on EBay
![]() | #14 | ||
Posts: 13 Thanks: 0 Trader Rating: 0 ![]() | Re: Newbie alert Thanks for the replies. Changed the adapter next to the cl socket, the aux works and lights up but MP3 still not working.
500 (Classic) Newbie Alert! | The Whitakers | Newbie Central | 5 | 05-04-2017 23:18 |
500 (USA) Newbie Alert | Foxyloxy | Newbie Central | 1 | 22-01-2017 21:22 |
Newbie alert | HJS01 | Newbie Central | 0 | 20-01-2017 01:44 |
Punto (Mk2/2b) Newbie alert | lottysvdub | Newbie Central | 13 | 07-08-2012 12:20 |
hi! newbie alert! | daveyj | Newbie Central | 3 | 18-04-2010 12:18 |
