Panda Help required
Panda Help required
carol edwards
Hi guy got a panda 1.1 active around June gear gave out clutch failed was advised clutch replaced. Car was driving fu e but on this last weekend lost all gears again and clut h peddle stayed on the floor. Pushed it upright and hot car home it's hydraulic checked fluids all OK any idea reluctant to drive it any distance in case it happens again
Posted in Sedieci section too..
Same advice:
https://www.fiatforum.com/500/482052-sticking-clutch-pedal.html
The clutch pedal going to the floor means the clutch cable or hydraulics have failed. Cable is cheap. However, UK cars have a hydraulic clutch system. The internal seals are usually worn out when the clutch fails. Bleeding air out of the system may work for a while but worn seals suck in more air.
You will need the master and slave cylinders which come filled with fluid. Replace the whole system. The same parts are used on Fiat 500 and Panda. LuK are a good brand but watch out for prices.
eBay item numbers 333487244985 and 303605601125 should fit.
