Hi, Can anyone help? I've just fitted front fog lights to my 2007 scudo van. All the wiring was there in place behind the front black covers which just plugged straight onto the back of lamps. (power was also there). I cant get the lamps to work. Then I realised that the switch on the indicator stalk only shows the rear fog lamps. Should my front ones come on with this same switch at the same time as rears or do I need to change the stalk to include front switching? Is there any re-programming needed also? Regards.
