Good evening all hopefully one of you kind people will be able to help? I own a 2008 Punto 1.3 multijet diesel 119k on clock. I've had the car about 8 months and never had any issues till now. Hopefully I can explain this right. The car starts fine no issues no warning lights or fault codes registered or no rattles and bangs. Problems occur if you start it and pull away straight away the revs die (doesn't stall) you can put the throttle pedal to the floor and after a few second revs will begin to build very very slowly Then once at around 3k rpm it will rev ok and drive ok. but if you start it and leave it for a couple of minutes it's ok no issues with revving. but here's the but if you try to accelerate hard it will bog down like brakes been applied give it a few seconds then all ok (this can happen at random times) so before i start throwing ££££ at it is there any common issues with these engines that could cause this hopefully someone can help
