Thread Tools
Old 11-09-2019   #1
Hello and engine help..
Hi and hello...
Ive just bought my son a fiat panda 2005 1.2 ..
Cracking little car, if i could get it running. Ive just fitted a replacement engine.
When engine arrived it was a little different. Rocker box, alternator pully. Etc. So swaped it all over from old engine and ..... it wont start.. ive put some fuel down the manifold and she fires iti life.. ive spark and fuel but it refuses to start.. ive replaced fuel pump.
Has anyone had same problems.. fixes?
Thanks in advance...
Daleboy is offline Reply With Quote Quote
Old 11-09-2019   #2
''LUIGI''
2668GRIFFIN's Avatar
2668GRIFFIN has donated!
Re: Hello and engine help..
I would imagine the ecu is not compatible with the new engine as you say it is a
different one to you old
LUIGI
2668GRIFFIN is offline Reply With Quote Quote
Old 12-09-2019   #3
You must have the complete set of imobiliser chips, engine ECU, body computer and instrument panel. They permanently lock themselves together when first powered up. Try the original engine ECU and see how it goes.
DaveMcT is offline Reply With Quote Quote
Old 12-09-2019   #4
Netherlands
If it runs on fuel you supply, I'd consider looking at the cranksensor. Maybe the sensor from the old engine can be swapped.
gr J
"Look for the ridiculous in everything and you will find it". - Jules Renard
A3jeroen is offline Reply With Quote Quote
Old 13-09-2019   #5
Trader Rating: 1
portland_bill has donated!
Your original engine would have had the 'square' oil cap and the 'new' engine has a round one, next to which is was a cam sensor.
The later engine uses both crank and cam sensors to arrange the spark, so the crank sensor may be different. Worth swapping from the old engine.
As long as you are using your original ignition system complete, all should work. The engine is a mechanical lump, with only minor changes for the later engine, so the electronincs will not sense that. But of course you don't know if the original ignition system was ok.
So why did it need an engine? These are very robust and last for ever if cared for. The electronics however can give up. You might now be trying to fix the original fault, and the engine might have been red herring.
Give us some more details of original failure and diagnosis.
Likes Eklipze3k liked this post
13 years motor trade, 16 years motor industry. 14 years Driving Instructor & 7 years Fleet Trainer
Panda Alessi
portland_bill is offline Reply With Quote Quote
Old 13-09-2019   #6
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
Following on from bill's post above - some more info about the original problem, and indeed which engine we're dealing with, will definitely help.
Eklipze3k is offline Reply With Quote Quote
Old 13-09-2019   #7
Thanks for reply's.
IT RUNS.... so the bottom pully is different. Different timing marks on the inner cambelt pully, the camshaft pully is also different and cannot be changed, as camshaft is larger, and the top timming sensor is shorter.have been really stumped.. fuel, spark.. i removed timingbelt and found no pully timing marks so static timed everthing, after all this i resprted poiring fuel in it again and again...
Then i thought ill just change map sensor for the spare that cam with engine and boom off she went like a little sewing machine. bloody map sensor was faulty. Went to fit alternator belt and its different again. Little fix. So tommorow we shall see..
Bought it with headgasket blown non runner for my son.removed head and looks like the reactor no4 and chernoble, man that must of got hot!! Agsin thanks for yoir advice.
Old 14-09-2019   #8
Trader Rating: 1
Hopefully top pulley still looks like a pulley. Then it shoud be the 60hp engine, so a replacement for the original.
Later still had 70hp engine, with variable valve timing. Top pulley houses the timing adjuster mechanism, so looks different.
The intermediate engine was different with timing belt, tooth profile, and tensioner was now automatic. There are no timing marks. Some pulleys have some marks, but they may not align with anything meaningful.
Get a Haynes manual and read the differences. When timing belt needs replacing, you'll need holding tools and follow the intermediate procedure in Haynes.
Spark plugs are smaller thread size. You'll need NGK DCPR7E-N-10, short code 4983.
Cam cover gasket is different.
Oil filter is different, yours should be 64mm dia seal.
All engine bits will be listed as 'From eng no. 2533528'.
Likes Pugglt Auld Jock liked this post
Panda Alessi
Thread Tools
(T) Check Engine light, ESP & Hill Hold Not Available, Lumpy Engine. :( jrwilshire2003 500 7 08-09-2016 12:25
(T) Engine stop during normal ride! Help regarding yellow engine indication in dashbord alexander90fiat60punto03 Punto (Mk2/2b) 13 18-10-2014 18:59
(T) Engine light on / check engine message and eBay car diagnostic kits fantasticdave Grande Punto 8 08-03-2011 14:18
(T) Engine Management Warning Light-engine loss of power/cutout Loobylou Doblo 10 27-09-2010 12:00
(T) motorcycle engine fitted in rear engine fiats pls join my other thread loadsofx19s 126 5 02-05-2008 16:07
