Hi there
Seems like no one responded to my previous thread, I am still having problems with my Fiat uno. 3 weeks back my car broke a timing belt after replacement the car was no longer in good state, it started to act up high and rough idling cutting every minute I slow down, I replaced every necessary part I thought it could be the cause of the problem from changing carburetors, buying a new ECU/Module, distributor, spark plugs still to no avail. No one responded to my previous thread please help am stuck the car however it's starting fine when driving locally it would cut everytime I slow down or stop. Yesterday I decided to go on a high way I took 200km run the car was running perfectly with 100 to 120km but a bit lazy on uphills as the carburetor wouldn't be adjusted however it drove well and back home. This morning I went to see a mech and he suggested I do the engine rework and I think that's insane, how can the car still be running when it needs the engine overhaul. When you listening to the car while it's idling the rpm is going high and low as if someone is stepping on the throttle. Please help
