Panda 1.1 active stopped working need help!
Sherylhughes79
It's 2007 model had it since Feb 2018 no problems but about a mo th ago started running lumpy did numerous things, spark plugs hdc leads, coil pack.
Did improve but didn't take problem fully away.
On Monday went to drive car got 10 yards then just stopped!
Husband has checked spark, changed tdc still not working,
Any advice please?
Try the spare key in case its the imobiliser.
Can you haer the fuel pump run when you open the driver's door? if not you'll need to confirm that fuel is getting through.
After that www.multiecuscan.net has a free version but you will need the connecting cables. Do not buy from eBay there are a lot of fakes.
