Old 19-07-2019   #1
domson1 has donated!
Speedo not working abs light on brake light and engine light
Help please. Fiat bravo 2007 1.4
Speedo stopped working and abs light with red brake light on together with engine light. With multiecuscan codes c1003 under steering section which won't clear. Two other codes under abs section for body computer and can bus. These two codes will clear but come back on when starting vehicle. Totally at a loss and would appreciate any ideas as not much info on bravos out there. Also my son says steering feels different even with city button on. More stiff possibly. Thanks
domson1 is offline Reply With Quote Quote
Old 19-07-2019   #2
Re: Speedo not working abs light on brake light and engine light
Also u1700 (body computer bcm/NBC) and u1601(can line error) are the other codes.
Old 19-07-2019   #3
varesecrazy has donated!
Hi.
Please give some background info.
Any work recently.. anything no longer working?
Did this happen gradually.. or 'overnight'
Look in the Grande FAQs.. random electrical thread.
Plenty of things it could be.. but rule out bad earths and water in fusebox..etc.
Charlie
varesecrazy is online now Reply With Quote Quote
Old 19-07-2019   #4
Thanks for the reply. No work recently. Got in car and lights came on and noticed Speedo not functioning. I did hook up multiecuscan today to see if abs sensors were working and the were showing equal movement of speed on laptop while driving. Which earth's do you mean please? And their locations? All fuses checked in engine bay and all fine except one 30 amp one behind glovebox that had no feed on either side.
Old 20-07-2019   #5
The speedo will be driven by the body computer from the ABS system.
You need to find what that 30A fuse does. What's the betting it's the ABS system.
DaveMcT is offline Reply With Quote Quote
Old 20-07-2019   #6
Thanks for reply Dave. Fuse isn't abs system unfortunately. However the handbook suggests ebd failure when the two lights on dash are showing.
Old 20-07-2019   #7
Quote Originally Posted by domson1 View Post
See GP section
Old 20-07-2019   #8
I've just read that faulty abs pump can cause ebd lights and speedometer failure. I can change the pump but does the pump have to be bled using software anyone? Any info on abs pump bleeding on bravo 1.4 2007?
Old 21-07-2019   #9
Check fuses now, cleaned earth's in engine bay. No luck
Old 21-07-2019   #10
You have a dead fuse so need to find what it powers and why there is no power to it. I don't believe in coincidences so it likely a wire or connection pin has broken and that's the one that powers the ABS system.
Old 22-07-2019   #11
Sorry I should have noted that on checking fuses again the dead one was heated rear window and it works.
Old 22-07-2019   #12
I have not used software to work on ABS..
But did have a blown ABS fuse on a punto sporting.
Old 22-07-2019   #13
Does anyone know if the ABS motor turns at ignition on? It could be an issue with the motor or the brushes. There are videos on YouTube showing how to change ABS motor brushes.
You need to get www.multiecuscan.net connected with the correct OBD cable and see what it comes up with.
Old 23-07-2019   #14
Popped into Halfords, came up with many faults Can bus related/ body computer. However also showed a short on alternator? Any ideas?
(T) 1.2 elx 8v no speedo, no abs light, abs kicking in... Trodai Punto (Mk2/2b) 4 11-09-2016 19:35
(T) ABS light, DTS light, and ESC light on Cally 500L 2 05-02-2015 20:02
(T) One Brake Light Stronger + One Position Light Dead + No Fog Light PaulComan Stilo 0 21-10-2014 13:19
(T) 2005 fiat croma no power steering abs light on speedo not working 2006alun Croma 12 30-07-2013 12:13
(G) ABS light not working. erbitrude Multipla 0 01-03-2013 10:34
