im Axle Specialists
Thread Tools
Old 30-06-2019   #1
Help. Weird oil leak
Daughters car has developed an oil leak 2017 1.2 500 Riva
Out of warranty by a month.
Oil leak from a blanked off point on the rocker cover. It's at the front of the rocker cover and is about 4mm diameter. Tried putting an image but don't seem able to
Any ideas if this is a replaceable bung and if so what is the part number?
Ta for any advice.
Owdgit is offline Reply With Quote Quote
Old 30-06-2019   #2
varesecrazy has donated!
Quote Originally Posted by Owdgit View Post
Ta for any advice.
The car should have a 3rd year on the warranty.
Look in the Newbie section for photo advice.. yellow section at top
Charlie
Old 30-06-2019   #3
Quote Originally Posted by varesecrazy View Post
Charlie
Thanks for the reply. I'm sure it says 2 years warranty and 3 years parts and labour servicing.
Probably worth seeing what the local stealers say.
Old 30-06-2019   #4
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: Help. Weird oil leak
Don't forget it's not just warranty, the car has to be of adequate quality so if it is manufacturing defect they should fix it regardless of warranty.
Ask nicely and see what they say.
Robert G8RPi.
Likes varesecrazy, Owdgit liked this post
g8rpi is offline Reply With Quote Quote
Old 01-07-2019   #5
Quote Originally Posted by g8rpi View Post
Robert G8RPi.
Took it to the dealers and they said they have never seen one leaking from that point before. Booked in for a replacement rocker cover under warranty.
Cheers for the comments.
Likes varesecrazy, g8rpi liked this post
Old 01-07-2019   #6
Good stuff.. you are very welcome
Thread Tools
(T) 1.4 8V Oil Leak from Head Gasket / Oil Seal? Terenc3Le3 Grande Punto 3 06-09-2016 15:36
(T) Seicento Oil leak & seperate Water Leak from Head?!?! Please help. Hamilton Cinquecento / Seicento 22 21-10-2010 12:45
(T) Oil leak fixed, but still leaks oil... punto2009 Punto (Mk2/2b) 5 19-08-2009 18:39
oil leak, no oil leak, that is the question? new to hgt FIAT Boo Archives 5 07-03-2006 19:30
(T) Oil leak, tappets, now engine whine and oil burn Extintor Punto (Mk2/2b) 5 15-11-2005 11:15
