Hi All,
I'm hoping to gather some information, and hopefully some help if anyone is able to assist me?!
My Fiat 500 twin air is having some issues with the clutch, and engaging gears. Reverse is the worst - and 'grinds' into gear when I select reverse.
The car has done 35,000 miles which I thought was a bit low for a clutch change? I've had a look on line, and someone mentioned about trying to select the gears with the car ignition off, which seems a lot smoother, and less difficult to select the gear. A bit of research suggests it may well be the Bearing in the flywheel.
Has anyone else witnessed this issue, and can anyone advise me if I will have to replace the whole clutch or just the bearing?
Thanks so much in advance guys...!
