- Jun 6, 2019
- 28
- 18
Hello everyone. How ya doing [emoji6]
Although it's not frequent, it's annoying nonetheless. From time to time, when parking (mostly) when i try to fit 1st or reverse it just won't go all the way. I have 2 options: fit any other gear (don't need to release the clutch pedal) and 1st and it is good to go or blip the throttle then fit 1st. I even once thought i was in reverse (before i even knew about this), i started to move and almost instantly the gears started to grind, because it wasn't fully engaged [emoji848] Idk if it is just normal behavior or something worse. If you could help me out it would be appreciated [emoji846]
