Thread Tools
Old 1 Week Ago   #1
Power steering/battery issue
Good Morning all and thanks for the add .
My son has a 2006 Grande punto and has an issue with the battery light coming on and then the loss of power steering.
It is ok when you first start in but comes on after about 10 mins,you can then turn the car off and start it again and then it lasts about another 10 mins.
have changed the battery and cleaned up the 4 earths but does anyone have any other ideas??
thanks
Brian55 is offline Reply With Quote Quote
Old 1 Week Ago   #2
Belgium
Re: Power steering/battery issue
Hi Brian,
the bad thing is that it keeps on happening every 10min, the good thing is that it's repeatable !
I would monitor the actual battery voltage, either with OBD and MES or with a voltmeter hooked to the battery terminals. If the volatge actually drops below 12.6(ish)VDC with engine running, the charging circuit is at fault, if it stay steady 13.6 to 14.4 VDC, your charging circuit is ok but you probably have a bad grounding / roten cable ...
BRs, Bernie
Old 1 Week Ago   #3
Thanks Bernie
Will try that out
Old 1 Week Ago   #4
Sweden
I had about the same problem ... measured the battery and everything looked good, but when the cold came, it couldn't start the engine. Measured battery power during engine start and voltage dropped to 6 volts. Bought a new battery and after that the problem has never returned with the steering wheel again
Draken is offline Reply With Quote Quote
Old 1 Week Ago   #5
Belgium
As said many times earlier : most of the time when a battery shows signs of weakness when winter comes and weather gets colder, it's time to replace it ...
But in Brian's case it has already been replaced so the source of the issue sits somewhere else. Usual candidates are earth points, earth cable(s), distribution/fuse box (corrosion, moisture etc), broken cable, worn insulation ...
A good visual inspection and some methodic troubleshooting should help find the culprit ...
BRs, Bernie
Old 1 Week Ago   #6
Thanks Guys
looks like i will be a busy boy on saturday trying to trace this down but you have given me places to start, bloody kids cars
Brian
Old 1 Week Ago   #7
Dean
Zeewulf's Avatar
Zeewulf has donated!
Quote Originally Posted by Brian55 View Post
Thanks Guys
looks like i will be a busy boy on Saturday trying to trace this down but you have given me places to start, bloody kids cars
Brian
Do what my dad did when I was young (many many moons ago), would supervise while he made me fix the problem on MY car. Used to hate doing it as it always took me ages to do (dad was a mechanic at the time), but thank him for it these days as I've now gained enough knowledge to tackle most things on my car (unless it needs a car lift to do).
Blue & Me Website - http://www.blueandme.net/blueandme/index.aspx/
Zeewulf is offline Reply With Quote Quote
Old 1 Week Ago   #8
Morning Guys and Girls
Update on the above ,having checked the voltages they are as follows
Battery read 12.2v then, when the car is started it drops to 11.8v if i put the lights ,heater etc on it drops to 11.3v ,it then runs for a couple of minutes before the battery light comes on and we lose power steering although the voltage doesn't drop when this happens.
Any ideas??
Brian
Old 1 Week Ago   #9
kjeldio has donated!
kjeldio is an honorary friend of the forum :)
Denmark
Hi Brian !
Change the alternator, (not easy when aircon) I have done that lately, I might come up with a howto.
BRs. Kjeld
kjeldio is offline Reply With Quote Quote
Old 1 Week Ago   #10
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
As above, not charging - should be about 14v with the engine running as per Bernie's earlier post. Either the alternator is duff, or the wiring from the alternator is damaged.
Eklipze3k is offline Reply With Quote Quote
Old 1 Week Ago   #11
Thanks Guys
Was hoping it wasnt going to be that but had a horrible feeling it was
Old 6 Days Ago   #12
Belgium
Hi Brian,
while you are busy with the alternator (check connections BEFORE replacing it !!), do the water drain upgrade to avoid future water ingress in the alternator ...
BRs, Bernie
Old 6 Days Ago   #13
Pugglt Auld Jock has donated!
Quote Originally Posted by Zeewulf View Post
Tried this with my boys. One just doesn't have any interest at all and is "handless" - takes more time correcting cross threaded screws etc to be worth it! The other is very capable with his hands but has always been "too busy" and is these days too busy with his business. Ah well, their loss. (or perhaps not so daft, as Dad often just ends up doing it and paying for the parts too if it's nothing too pricey!)
Pugglt Auld Jock is offline Reply With Quote Quote
Thread Tools
(T) Wouldn't start, immobiliser issue + power steering issue - or so I thought tttonyyy Grande Punto 5 22-08-2017 21:52
(G) Please help with grandad's car - Steering/Battery issue Roger100 Grande Punto 9 27-02-2017 12:18
(T) Power steering issue feldano Punto (Mk2/2b) 1 10-06-2014 11:41
(T) Power steering issue wellsy87 Grande Punto 2 30-12-2012 01:15
(T) Power steering issue Guysmokey Bravo 8 20-09-2012 15:34
