Thread Tools
Old 27-01-2019   #1
Frequent clutch failure
Hello all Iím new on here, having real problems identifying why my clutch on my 1.9 doblo is failing every 7-8k! Each time itís the release bearing that collapses. Iíve swapped everything including the guide tube and still itís failing prematurely. The vehicle isnít driven hard and clutch pedal isnít being used as a footrest!! Only thing Iíve not swapped is the clutch release arm that actuates the bearing and releases the clutch. Has anyone experienced similar problems-totally at wits end with this.
Taxi276 is offline Reply With Quote Quote
Old 27-01-2019   #2
varesecrazy has donated!
Re: Frequent clutch failure
Hi
which engine jtd or mj?
Just so we talk about the correct kit..
Can we have a bit of background info.
Time in ownership other work done. Etc
Charlie
Old 27-01-2019   #3
Itís jtd, Iíve owned for 3 years and I use as taxi, obviously mileage is high but previously a clutch would last 50k plus.
Old 28-01-2019   #4
Check the clutch release arm is not twisted have had that on other vehicles over the years I was in the trade, allows the bearing to come down not square with pad on cover.
Check for free movement as well in cable, pedal, & gearbox pivot arm
Likes g8rpi, varesecrazy liked this post
500e is offline Reply With Quote Quote
Old 28-01-2019   #5
Quote Originally Posted by Taxi276 View Post
Ok.. so when did the last 'good clutch' fail.
In what way fid it fail..
The new ones?
How many clutches..how many bearings..
Distances covered etc..
The suggestion of an 'out of square push'
Sounds VERY plausible.
Old 28-01-2019   #6
Had 2 both on BL\BMC carbon release bearings I think they failed due to a damaged release before the problem started causing arm to twist the twist was not a really noticeable amount an 1/8 or so if you have box out put a strait edge across bell housing & measure either side of bearing to SE, do it at full travel & at rest, don't forget to check any bushings in Gbox if any & the other things I mentioned
Never looked at the Fiat clutch all ours did 150K without clutches or flywheels, so maybe a concentric slave cylinder, (still check for square if possible) did have the stupid plastic clutch cylinder push rods break though.
Old 28-01-2019   #7
Moderator
g8rpi's Avatar
g8rpi has donated!
+1 for 500e's suggestion of uneven release arm pressure. Check the pivots while you are in there. If one is worn or cracked it will cause a similar effect.
Robert G8RPI.
g8rpi is online now Reply With Quote Quote
Old 29-01-2019   #8
Hi thanks for all advice folks, garage stripping car tomorrow and new clutch kit and release fork being fitted. Hopefully this time Iíll get more than 8000 miles out of clutch!
Old 29-01-2019   #9
Lets hope the damage is pretty obvious once apart..
Do let us know what happens longer term
Charlie
Thread Tools
(T) What causes frequent regen? Icklet Punto (2012+) 8 06-08-2018 20:03
(G) Clonk is more frequent now Advanced Driver Panda 5 26-03-2010 20:18
(G) MOT failure list for those who don't frequent LL SkinzCinqSporting Cinquecento / Seicento 17 21-11-2006 20:05
Help! Any plumbers frequent these forums? default_user Leisure Lounge 29 08-06-2006 21:03
hey, im a frequent viewer but just joined! craig316 Newbie Central 7 30-10-2005 16:58
