Hello all I’m new on here, having real problems identifying why my clutch on my 1.9 doblo is failing every 7-8k! Each time it’s the release bearing that collapses. I’ve swapped everything including the guide tube and still it’s failing prematurely. The vehicle isn’t driven hard and clutch pedal isn’t being used as a footrest!! Only thing I’ve not swapped is the clutch release arm that actuates the bearing and releases the clutch. Has anyone experienced similar problems-totally at wits end with this.
