Thread Tools
Old 26-01-2019   #1
Greece
Angry temperature red light indicator
ello i own 1.1 seicento and i have noticed that i get temperature red light indicator but water is good no leaks or below the minimum and they are warm i sort it out the fans and the fans worked fine the only problem is the plug of the fan ( i fixed by the way) but the red light in the dash is still open and i am guessing a electrical problem PLS HELP and the red light does sometime be a strong red light but sometimes is fading WTF?
fiatlover4life is offline Reply With Quote Quote
Old 26-01-2019   #2
varesecrazy has donated!
Re: temperature red light indicator
That light is supposedly indication of the engine generating excessive heat.
As you say it could be poor wiring connection
Old 26-01-2019   #3
Moderator
g8rpi's Avatar
g8rpi has donated!
If the light is fading on and off it is possible that the temperature sensor has failed letting coolant into it and causing a partial short circuit.
First thing is to change the sensor, cheap and normally easy (I don't know what access is like on the Sei).
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Thread Tools
(T) temperature red light indicator fiatlover4life Cinquecento / Seicento 2 26-01-2019 21:03
(T) Temperature Indicator TwinAir 85HP TwinTurbo 500 7 22-02-2016 13:00
(G) Red Light Indicator MakEVO Punto Evo 5 11-10-2015 13:22
(G) Water temperature red light bruce400 Punto (Mk2/2b) 6 19-10-2006 17:36
Red warning light, Temperature problem Kenny FIAT Boo Archives 0 18-11-2004 16:23
