Doblo Big hello and a bit of help please
Love4bags
Hello everyone. Just joined the fiat club.
I have a doblo van xl and it's amazing. I've moved up from a smaller doblo and can't believe the space.
Anyway my husband serviced dotty as I called her but the new van is a 2013 model and quite a bit more complicated. The van is saying the oil needs changing as its degraded. A bit worrying as when bought the van had just been serviced!!!! Not to mention the fact that when setting off to get home it stopped as there was no oil in the engine!!! Thankfully we were near a garage and my husband had been reading the owners manual and new what oil to buy. Had to add 3litres to bring back upto full!!!
Problem is we can't find where the oil filter is housed. The engine is a 2.0 d multi jet 135 Bhp version.
So if anyone can help then he can change the oil and filter and get back to normal.
Many thanks
Carla...:confused:
Many thanks
Carla...:confused:
Hi. Often found under a domed metal cover on top of engine.
Will need some kit to reset the DPF stuff in the Engine ECU
Charlie
Charlie
Thank you. We will have a look tomorrow.
Already spotted a YouTube on how to reset oil change warning. All you have to do is stick your foot on the gas peddle and press the brake 7 times. Warning is reset and dpf (whatever that is) resumes.
Thanks Carla.
Charlie
Thanks Carla.
Hi Carla.
No problem.
Dpf .. a soot trap in the exhaust
Diesel
Particulate
Filter
Its complicated.. basically car works put how dirty the oil gets..
When you put clean oil and filter in.. you have to reset it.. or you get a premature warning (sound familiar..)
To reset the 'oil degradation index'
You need to plug into the
On
Board
Diagnostic
Obd port.. near drivers knee ;)
LOTS of info on here ..just SEARCH the relevant terms :)
Charlie
Hi Carla.
No problem.
Diesel
Particulate
Filter
On
Board
Diagnostic
Charlie
Hi Carla & welcome! Charlie's given you some excellent advice there.
At the risk of sounding like a "know-it-all", because I don't (know it all that is - but there are some on here who pretty much do!) I would say that, although you may get a result of some sort from your pressing pedals reset procedure I think it unlikely it'll do it properly. The ECU (computer) needs to know that the oil has been changed so that it will do DPF regenerations properly. If it thinks an oil change is needed it will either stop doing regens or try to do them repeatedly - far more often than normal. Either result is likely to be detrimental to this soot filter (DPF) and they are not cheap to replace (our local independent Volkswagen garage quoted £1500 to do the one on my son's Fabia. Main dealer wanted over £2000 - I actually felt faint for a couple of minutes!!! I thought about doing it myself but the filter alone was about 2/3 of the cost).
I would suggest that you need "Multiecuscan" which is a program that runs on a laptop. It comes in various versions and the more basic versions are very affordable. I first heard about it a few years ago when I first started "lurking" around on this forum (The "family fleet" includes a Punto and a Panda) It uses an interface that plugs into the OBD port mentioned by Charlie and will let you do almost anything the Fiat dealer can do with his expensive set up (and a lot more than generic equipment). I, at 72 years old, am a computer idiot. But, having owned my copy of MES (Multiecuscan) for a bit over a year now, am able to do all the simpler service and fault code related functions and I'm now getting into the more complicated "stuff". One of the most useful features is that it "leads you by the nose" because it includes on screen guides as to what action to take and makes suggestions as to fault code diagnosis. You can download a free version from their website and run it in simulation mode which lets you see how it works and what it can do. Please also give the helpful people at "GENDAN" a ring and talk to them about it. They are official distributors and even if you decide not to buy one of their packages you will find them very helpful. I actually bought my kit from them and greatly appreciate their ongoing support. There are many forum members who use it and the depth of help and knowledge available here is prodigious! Your Hubby sounds to me like a person who would quickly master it!
All the best for the year to come
Jock
By the way Carla. Just so you don't feel too anxious, My friend at the Volkswagen garage tells me that a well maintained diesel should see at least around 100,000 miles out of it's DPF. Our Fabia's failed at 95,000 but it runs a slightly modified ECU program which is probably the culprit.
You may also know that vehicles fitted with a DPF need to get a periodic, uninterrupted, steady run at constant speed for, maybe 20 minutes or so, such as a cruise on the motorway or a dual carriageway without roundabouts, for the regeneration process to be properly completed. Excessively high revs are not needed but 4th gear, rather than 5th is probably beneficial. A diesel that spends it's life pottering around town is highly likely to suffer repeated problems with its DPF and, although a forced regeneration (Multiecuscan can facilitate this) can be performed it's not a long term way to treat the DPF and is likely, if used repeatedly, to lead to early DPF failure. Nothing works as well, or is as cheap, as a weekly run up the motorway!
Best wishes
jock
Best wishes
jock
Cheapest solution:
Unless the m.way trip is to an
'outlet village' ;)
