Thread Tools
Old 09-11-2018   #1
panda 4x4 rear transmission oil
Hi. (this is my first time on the forum). I have just purchased a Fiat Panda 2014 4x4. I am wanting to check the oil in the rear transmission box but want some oil available. book says tutela transmission cross SAE75-85 synthetic. Some sites say if you get the wrong oil it can damage box. Which oil do i need. Any help please Thanks Paul
parmiss is offline Reply With Quote Quote
Old 09-11-2018   #2
Turkey
Re: panda 4x4 rear transmission oil
I can't remember if that's the right differential oil (someone more knowledgeable than myself might chime in), but something to note is that the rear differential is a 'lifetime sealed' design in that it's not supposed to have any fluid changes, unless you see signs of leaks or fluid weeping around the housing and case gaskets. If you do, however, end up needing to change the differential fluid you'll also need the gasket to be replaced, which is tricky because Fiat tends to bundle the whole rear diff as a single part rather than providing individual replacement parts for it.
oyumurtaci is offline Reply With Quote Quote
Old 09-11-2018   #3
Quote Originally Posted by oyumurtaci View Post
I changed the rear diff oil on a 2013 MJ 4x4 a few months ago. Drain plug at the bottom, level/filler plug half way up, no need to interfere with any gasket on that car.
Jabe is offline Reply With Quote Quote
Old 09-11-2018   #4
Netherlands
Check the manual if it needs GL4 or GL5 and use the right spec.
gr J
"Look for the ridiculous in everything and you will find it". - Jules Renard
A3jeroen is offline Reply With Quote Quote
Old 09-11-2018   #5
Quote Originally Posted by A3jeroen View Post
gr J
The OP has quoted from the manual...
All it says (for the rear diff of the 4x4 and Cross models) is "SAE 75-85 grade synthetic lubricant" and lists Tutela Transmission Cross as being the original lubricant. (The latest version of the manual no longer says this brand of fluid has to be used, as they are not allowed to. Only to 'recommend' a particular brand)
For the gearbox, and the integral front diff, on the 4x4 and Cross models, it is more specific: "SAE 75-85 grade synthetic lubricant, which exceeds API GL5 specifications", and suggests Tutela Transmission Multiaxle.
Likes johncard007 liked this post
2018 Panda 4x4 MJ :: North Herts :: Remember, if you find a post helpful, press the smiley face 'thanks' button below
Herts Hillhopper is offline Reply With Quote Quote
Old 10-11-2018   #6
Turkey
Quote Originally Posted by Jabe View Post
Reading my post again, yes I should have been more clear. If there is visible weeping under the housing, then the gasket should be replaced not just the fluid, as it's most likely the gasket that's not sealing properly. I was trying to say if there are signs of leaking then the gasket should be changed with the fluid and not just topping up.
Old 10-11-2018   #7
Netherlands
GL5 says more than 75W85
So GL5 it is.
Oh! Make sure to loosen the fillerplug before the drainplug. Real shame if the fillerplug is stuck after draining...
gr J
Old 11-11-2018   #8
Cheers guys. thanks for your replies you have been a great help. Thanks
Old 11-11-2018   #9
So GL5 it is.
gr J
Trouble is, it only says 'GL5' for the front end - no GL spec given for the rear diff...
Old 04-12-2018   #10
So GL5 it is.
gr J
Absolutely a great idea, a case of uncommon common sense! I probably would not of thought of that.
johncard007 is offline Reply With Quote Quote
Thread Tools
(T) hello panda lovers - 1987 4x4 transmission advice highland panda Panda (Classic) 4 08-02-2014 14:30
(G) Panda 4x4 MJ Cross - Transmission rattle 4x4 Panda 6 20-12-2010 13:04
(Tu) 500 + Panda 4x4 transmission interchangeability ohtagerbilhero 500 10 19-03-2010 08:50
(T) Panda 4x4 - Oil leak (rear drive shaft) Frenchy197021 Panda 5 08-05-2009 23:33
