Newmotorhomies
- Oct 16, 2018
- 22
- 5
This is my last silly question..... I have found an engine 814027S. What does the s mean? Will it the right engine?
Thank you in advance ?
The S suffix indicates common rail direct injection. This has different injectors. I don't know for sure but am pretty certain that it will not be compatable with the ECU and fuel system on your van. If your engine has a mechanical pump with a separate fuel line to each injector the 27S won't work unless you swap the ECU, which is not practical. I doubt the non-common rail injectors would fit the 27S head but it's moot as you have a trashed injector.
Robert G8RPI.
Correct,
I'm tired, What I was trying to say was unless he swapped TO the ECU pump etc for the common rail engine. Too much for the OP I think.
Thank you. All I want is an engine ?
I am having problems understanding anything to do with this motorhome. Thanks for all your input. Much appreciated.
