Hi can any body help?
I had the amber check engine light on and was told by the dealer it would cost £467 to fix with a new sensor. Having read lots of info about this problem I ordered a replacement of the same type from Ebay.
I also got a copy of multieuscan and an elm interface.
I fitted the new DPF sensor and checked the readings. I get P2452-11 which is short to ground according to multieuscan.
I checked the wiring and it is fine. If I unplug the sensor I get a sensor open circuit code
Is the new sensor faulty?
