The Potter147
- Oct 23, 2014
- 3
- 2
Hi, I've never posted on the forum before, but I'm looking for any advice I can get before I have to fork out mega bucks to sort this problem. The Engine Management Light has been on for over two years, it is not affecting performance nor fuel, however, thanks to the recent changes in the MOT, the fact that it is on is now a fail. I've had a Fiat fault code done and it showed as poss EGR valve either clogged or needing a replacement. Today after further inspection, I was informed my my mechanic that the EGR valve is fine, but the light is still on. He took it out to blow it through and said it was ok. (It seems that they can get clogged up and need a blow through).
The mechanic noticed that the coolant fan hasn't been working, he by-passed the ECU and got it to work, he then suggested that there may be a break in a wire somewhere between the ECU and the coolant fan which is causing the amber light to stay on. The mechanic suggested taking it to Fiat to put it on a diagnostic machine to check the ECU and has suggested that worst case it may need a new ECU.
I'm not sure because who's to say the ECU could be replaced and I find my light is still on.......at my wits' end because I can see it being a lot of money. It's an Autotrail Dakota, 2007, 3 litre engine, 160 bhp, Fiat Ducato. Any advice or pointers would be much appreciated. Thanks in advance!
Bill
Bill
