Hi everyone, thanks for letting me be here.
My name is Eddie and im a tyre fitter with a headache lol
Firstly ive taken on the task of replacing the chain on a 1.3 doblo.
Ive done belts and chains before albeit a few years ago however this we van has my head thumpin lol.
When i got the van, which is one of our own but from another branches van, it had complained of lack of power, and cutting out and definate top end rattle around chain casing area. Prevoius mechanic done an oil and filter change about 600miles ago. The van cut out and they decided to then change fuel filter, they got it going but still had no power.. assumption was chain jumped the timing.
I stripped it all down and found the chain guide right side was baroken..
The plastic were in the sump and the chain was guiding on the metal..
As i diding have the correct locking set, i timed cams up roughly using an 8mm allen key and replaced the chain kit etc...
I ordered the kit from ebay which i had to file .5mm off each side to get it to lock the 2 cams, then i found tdc through datum hole on bhousing, and locked it there...
I torqued up crack bolt and cam bolt and continued building up...i did also clean the oil pipe going to chain tensioner and checked for blockage etc...
So with all built back up its running with thankfully no oil or water leaks but still has no power and cuts out..
Other symtoms i can see are that when its first started it starts fairly quickly but when warms up it gets harder to start to the point of a second battery and strain on starter( seen some smoke)
It warms up really quickly, its very hot around turbo ,
It cuts out if any sort of load at all goes on...first test drive never made it out the gate....
No managment lights on
Takes a little longer for oil light to go out but does..
I then guessed maybe a blocked dpf, i loosened it from the turbo and set it back but still same symptons..
My quess is now the turbo but im just not sure if its timed up perfectly...
I torqued the crank and cams with the pins in place....
Is there another hole in flywheel for tge pin to slot in or is it just that 1?
And if i find the timing out am i right in thinking i can reset it without removing front casing again?
Please can anyone who knows these engines give me some insight before loose the plot?
Thanks for reading guys hope u can help
Ed
Ed
