ah timing a valver... seems a nightmare that it doesnt have marks but its not that hard really...
I highly recommend some timing tools, these cheapy ones is what i have
https://www.ebay.co.uk/itm/Engine-T...avo-Brava-1-2-16v-Twincam-Petrol/281941623655
But it is doable without if you can't wait.
1. take spark plugs out, just cylinder 1 & 2 but if you take all 4 out it'll be easier to turn the engine.
2. find 2 long thin things, they need to fit down the spark plug hole and they need to be the same length as each other, EXACTLY SAME LENGTH!! Put on in cylinder 1 and the other in cylinder 2.
3. Turn engine by hand until both long things are completely level - this engine is timed with the pistons all level and not at TDC...
4. on front of the head there is a plug, i've not got a pic to hand i'm afraid, but you unscrew that and if its timed up right you should see a slot in the camshaft. From memory a 11mm allen key will fit perfectly in that slot but having had the tools for years now it might be 10mm or 12mm, it needs to fit snug so the cam cant move at all.
5. slacken off the bolt holding the cam pulley on, just enough that the pulley will spin - its not got a woodruff key or anything so it can spin freely on the cam.
6. making sure you've not disturbed the bottom end (i.e. the markers you've put in cylinders are still perfectly level) put the belt on.
7. so now you have the cylinder level, the cam locked and the belt on you can tension it - you want to twist the tensioner so the 2 little lines on it line up, it tends to spring back a tiny bit once to nip it up so go just past the mark, tighten the tensioner up and check the lines, adjust if necessary. This is easy cause the top pulley is free to rotate atm without moving the camshaft itself.
8. Once you happy with tensioner, tighten up the bolt on the top pulley to lock it back to the camshaft. And you are timed up now.
9. remove whatever you stuck through the hole in the head to lock the camshaft and turn engine over several complete rotations by hand, then get your piston level indicators perfectly level again, poke the thing back in the camshaft to check its still in right place. Hopefully it is, i think from memory they can be level and your on the wrong stroke so slot in cam shaft isnt visible... Its been a while but from memory you want piston 1 going up and piston 2 on its way down but not 100% sure without looking it up. Assuming everything is still lined up just refitt the cam lock screw thing and put plugs and everything back in etc and your done. Its actually a really easy engine to time once you done it the first time.
If you can wait for the tools its much less scary as the cam locker is properly tight fit and there is not even the minutest bit of slop when cams locked. The process is exactly the same just you have proper tools rather than winging it.
