500 Clutch problem
500 Clutch problem
alann
Hi guys,really hope you can help,my granddaughter has a fiat 500 2012 plate,here goes..she had no clutch (no pressure on pedal ) So her dads friend some how come to the decision the slave cylinder was at faught so has a new cylinder fitted that was ok for 2 weeks then it went again so then had a new clutch fitted,that didnt solve the problem and the garage that fitted the clutch said the master cylinder had gone,so i then took it to the garage where i get my car repaired and got them to fit a new master,bled the system for ages got all the air out and couldnt get a pedal so left it to the next day,checked the pedal and it was working perfect so took it to my daughter and within a hour the pedal had gone again ..please can you help
That's all the bits replaced bar the actuator arm/system that acts upon the clutch?
I would check the slave cylinder travel whilst some ones pushing the pedal to see if it moves correctly and the same distance every time if it does and the arm going into the bell housing appears to work correctly you can see where my thoughts are?
And of course there's the pedal assembly to look at?
the rod coming out the slave cylinder is not moving
Its there a problem with the vacuum (i'm not sure if these are vacuum assisted like the brakes) it seems logical if everything else is replaced maybe the problem is not the the brakes themselves ?
