Thread Tools
Old 15-04-2018   #1
Engine leaking something?
Hi Iím new to the site and just bought a 63reg Doble 1.3 multijet and there is a clear oily fluid leaking from the left side of the engine as you open the bonnet. The fluid is clear but smells like oil but when checking the oil itís not low, can anyone help?
Thanks Dean
Deano carper is offline Reply With Quote Quote
Old 16-04-2018   #2
Trader Rating: 1
portland_bill has donated!
Re: Engine leaking something?
Gonna need a bit more detail.
Fluids used in the vehicle:
Engine oil. Not usually clear. When new can be quite a light golden colour, but gets blacker quickly in a diesel. Sniff the dipstick for a comparison. Try not to get it on your nose. Not a good look.
Fuel. Can change colour according to quantity and light. Small quantities can be light yellowish, but a cupful will appear more blueish. Smells different. Stick your nose in the fuel filler for a comparison.
Coolant. Should be pink. Might be just water if previous owner didn't care about corrosion or freezing. Remove radiator reservoir cap when cold - very cold - and compare.
Brake fluid. Light yellowish. If rubbed between fingers will leave them feeling dry as the natural oils are removed!
You need to try to follow the leak to its highest point to find the origin. Might need to clean the area and look again after it has run a while. If you clean and dry it thoroughly, shake talcum powder over the potential areas, should highlight the leak point. And make it smell lovely.
See what you can do, and report back.
13 years motor trade, 16 years motor industry. 14 years Driving Instructor & 7 years Fleet Trainer
Panda Alessi
portland_bill is online now Reply With Quote Quote
Old 16-04-2018   #3
Thanks bill I will take a closer look tomorrow mate and try and find the source
Old 16-04-2018   #4
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
I'd hazard a guess that's probably going to be brake fluid, it's where I'd be starting my search at least.
Eklipze3k is offline Reply With Quote Quote
Old 16-04-2018   #5
I have attached a photo and it looks like the leak is from the silver curved pipe in the centre of the pic as itís dripping directly below the grey rectangular box,
Thanks Dean
Old 16-04-2018   #6
Trader Rating: 1
The problem with a close-up, is that without a similar vehicle to look at, there is no context.
Leak 'from' the pipe. Is it dripping off, or is there definitely a hole in the pipe. It could just be a conduit for the fluid to run along.
Follow the pipe upwards to find what it is attached to, and where the fluid is coming from. That'd be more useful.
Brake fluid is a possibility. Might just be overflow, if the pads have been replaced, caliper pistons pushed back, and fluid expelled into reservoir and overflowed.
Panda Alessi
Old 17-04-2018   #7
When I check the oil and brake fluid levels they are not low which is odd, I will have a more detailed look now. Cheers Bill
Thread Tools
(T) leaking coolant and engine smoking foxfiat Punto (Mk1) 9 18-04-2015 00:42
(T) coolant leaking rear of engine JTD 1.9 numero-uno Stilo 9 24-08-2014 12:04
(T) Engine coolant leak/heating matrix leaking? Jbent Stilo 5 13-06-2012 01:01
(T) Leaking under the left handside of the engine mk68 Punto (Mk2/2b) 5 13-09-2007 14:22
Water leaking from engine Oli FIAT Boo Archives 1 13-07-2002 02:56
