I have a 2006 punto grande and the drivers side window won't open when the door is shut but if you open the door to a 45 degree or more angle it works perfectly any ideas please.
Seems to be a common fault on this model as others have said peel back the rubber that connects the door to body and do it on both doors if one side had a broken wire the other side won't be far behind either and may need some attention.
