Heater fan wire harness connections
timspu
Greetings to one and all.
I have a model year 2000 Peugeot Boxer 2.5 camper ( Fiat Ducato) and have just replaced the heater matrix. Having everything installed I have part of an electrical connecter which I cannot locate the male end. So currently the heater fan will not switch on. This harness is a patch cable harness which connects the heater resistor, fan and fan switch. One end connects to the vehicle harness on the left hand side of the stereo but I have one female block connector with nothing to connect to. I have pulled everything out and cannot locate anything. The fan did work before I took it apart.
My question is does this end of the harness connect to anything ?
I do not have power at the fan or the resistors, fuse is okay.
Scratching head as I cannot remember disconnecting it or removing a black box.
Any info would be appreciated
TIM
Tim did you ever sort your problem? Just did the same (2003 2.3 JTD) heater matrix replacement - sweaty or what! Have replaced all the dashboard pieces with no spare screws BUT the heater fan is not working. I did plug a connector into the fan unit, the control panel and the heater resistor unit. Was definitely working before. Like you, a number of female connectors 'hanging around'. There were definitely some beforehand. I wish I'd taken more photos.
Any advice / comment on the wiring connections for the heater fan?
Bev
