Issue with Fiat Coupe 2.0 16V
It is very difficult to start the car, once the engine is on, it can't rev and starts loosing power.
I have completely renovated the engine, the compression is fine,
- the engagement was checked many times and is also fine
- main parts that have been changed:
Fuel Pump
Furl Regulator
Distributor
Wiring Spark
Spark
Igntion Coil
MAP sensor
IAT senor
Tmepretarure sensor (injection)
Lamba Sonda
HALL sensor on Crankshaft
Clean Injectors
i tried using 3 different ECUs and there's no change with any of them
I've tracked the installation from the ECU to each Sensor and everything is fine.
Clip Run Engine =You are only allowed to post URLs once you have at least 5 posts. If you have a legitimate reason for posting before this limit, please contact a moderator who will assist you.
Also, I forgot to mention that the car has inlet manifold kappa turbo and the balance shafts have been removed
Fuel Pump
Furl Regulator
Distributor
Wiring Spark
Spark
Igntion Coil
MAP sensor
IAT senor
Lamba Sonda
Clean Injectors
