Problems with my fiat 500x
Lindsey0375
Help please
Newbie here , I have a fiat 500x 56 plate
When we turn the engine on the following warning have just started to appear
Start stop unavailable
Drive mode unavailable
Check engine
Check parking or electronic break
Any ideas what the problem could be , could it be easily fixed ?
Thankyou
The battery is reading 2 bars when I get in and goes up to 3 bars when I switch on , could it still be the battery ?
Just a bump for this one. We were out in our 500X MJ yesterday when the Check Engine Light came on/No S/S etc. Car appeared to go in to Limp mode as although I could drive it there was little acceleration. I pulled off to the side of the road and turned the engine off - waited 10 seconds then restarted. Lights/errors stayed on but car was then back to driving perfectly normal. Once we got back home I check the Battery indicator on the dash (although did not do a Volt-meter test as none to hand.) Looked normal. I then disconnected the S/S additional battery cable for 10 seconds and reconnected and now all errors/lights have gone and car completely fine. It was absolutely chucking it down so I initially thought water? Me and my big gob recently saying out car has been faultless although as mentioned no issues at all again now! It was close to Zero degrees this morning where I live and car starts fine - S/S functions as usual. Thoughts?
