500 Too bumpy!
500 Too bumpy!
Jilly C
Hello everyone. I have a 500 Sport 2008 plate and I love it except that the suspension is so hard that it makes every journey so bumpy. It's taking the enjoyment out of driving it. Is there anything I can do to improve it? All suggestions welcome ?
Switch to 14" wheels. The 16's are way too heavy. If you must have the looks you could compromise with a set of light weight 15's like those from Team Dynamics (pro race or something).
Sound excessive, replace all the front suspension and rear springs and dampers for OEM equivalent(parts are cheap), if they've never been done they're shot and yes higher profile tyres will help.
Has a previous owner "improved"(or not) it?
I don't think previous owner did anything. Would that be an expensive job? Sorry, what is OEM?
Hi Jilly, and welcome to FF,:)
the clue may well lie in the "sport" title.. ;)
but as others have said - at 9 years old it's probably not as it left the factory..either through "tuning" or just general wear and tear.
cheapest initial things will be ;
1, check the tyre pressures..
2,get a test drive in another - for comparison ( used car lots have plenty nowadays)
how long have you had the car ?
have you noticed any degradation..??
it may be - like me..that the "not 18 anymore" skeleton isn't as forgiving..:eek:
Charlie - Oxford
A good suggestion, but it depends which engine the OP has. Great if it's a 1.2, but 14" wheels won't fit on a 1.4 due to brake clearance issues. Wheel size (& hence tyre profile) makes a significant difference on the 500, particularly once you go above 15".
From memory, the only differences with the sport in 2008 were trim and cosmetics; IIRC they run on the same suspension as the lounge & pop models of the day.
Early 500's have poor suspension, particularly at the rear - I recall driving one shortly after launch and coming from a Mk1 Ka, the ride felt like swapping a limousine for a landrover; it really was a dealbreaker. Later cars from 2010 onwards have a modified rear beam, which changes the ride from bad to adequate (the beam is stiffer, allowing softer springs to be used); easily retrofitted and a secondhand beam complete can be had for not a great deal of money; you'll need the later springs & shocks as well if you do this.
If it's still on the original rear shocks, change them; OEM quality isn't the best and they'll likely be well shot by now. It may help a little, but don't expect miracles. Replacing springs won't help much unless you go for a much more expensive option like coilovers; the 500 is badly damped rather than badly sprung. Coilovers are generally well regarded but the cost of the upgrade wouldn't make much sense on a 9yr old car.
Even on the latest models, ride isn't the 500's strongpoint, but it's adequate for a city car.
As a matter of interest, how many miles are on this car? How long have you owned the car?
I agree with all of the above points, but keep things in perspective here, you have a 9 year old car, soon to be a 10 year old car. Do you really want to start spending money on it? As long as the vehicle passes its MoT, you'd probably be better off putting up with the firm ride and saving your money. If you really want a more comfortable ride, you'd probably want to consider buying a newer model depending on your finances.
Check your tyres. Make sure someone hasn't fitted Extra Load tyres on the vehicle. These will make the ride much firmer. Extra Load tyres are clearly marked on the sidewall of the tyre. Also, if they've got too much air in them, this will contribute to a firmer ride.
........... but keep things in perspective here, you have a 9 year old car, soon to be a 10 year old car. Do you really want to start spending money on it? As long as the vehicle passes its MoT, you'd probably be better off putting up with the firm ride and saving your money. If you really want a more comfortable ride, you'd probably want to consider buying a newer model depending on your finances.
Good advice there, and good advice for any car, let alone a Fiat500.
We recently sold our six year old 500, and although we didn't have to spend money on it, we knew that we would be forced to in the next few years. Fair wear and tear items like tyres and brakes are a normal stuff, but shocks and suspension wear out too eventually.
Keep it and put up with it, or sell it for a newer one.
By the way, OEM stands for Original Equipment Manufacturer.
Good luck,
Mick.
I have a 9-year-old 500 1.4 Sport which I've owned for years and yes, the ride is harsh and crashy - and always has been! Having said that, the unsophisticated ride certainly isn't bad enough to cause skeletal jarring to my ageing frame and I wonder whether replacing the rear shock absorbers and tyres might improve things with your car. Mine has 15" wheels (which I think was the standard wheel size on all the early Sport models so yours probably has these too), all of which are fitted with Michelin Energy Saver+ tyres that still have around 5 mm of tread. I rate these tyres for comfort, road noise and low wear rate and recommend them. At 5 years old I replaced the original rear shock absorbers with Bilstein B4s and these definitely improved things at the back, reducing the crashiness of the ride and the tendency to 'skip out' when driving around some corners.
The crude suspension set-up is certainly one of the downsides to the early 500s. In other respects I've been very happy with my 9-year-old. It's been superbly reliable so far and great fun to drive!
I think the only difference was that the Sport models came with lowered front springs (lowered by 30 mm I think). Mine certainly has a slightly more 'purposeful' stance vs a standard Pop or Lounge when viewed side-on.
Plenty of good advice above. MarginWalker makes a good point concerning tyres. If it is needing new ones, the Michelins he suggests sound good. A possible better alternative are Michelin Cross Climates, which soften the ride more and are quiet, as well as giving good grip in cold/icy/snowy conditions. If it's got 16" inch wheels with 45 profile tyres though, I don't think they are available in that size.
Whichever tyres are fitted, for the best ride inflate them to the minimum recommended cold pressure.
But be careful. Quite often the XL (Extra Load) versions are offered cheaper than the regulars. Don't take the XL versions if your goal is to make the ride more comfortable.
Thanks so much for all of this info. I shall give it all some thought.
You're probably right. It has 69,000 miles. Like me, it's getting old! :)
Good luck,
Mick.
Thanks Mick, I love it so will probably put up and shut up :)
Yes, I do have run driving it! And it can certainly move :) Thanks for the tips on tyres and rear shocks, I think I will probably invest in those. Many thanks
Thanks very much, I shall look into those tyres too. Much appreciated.
Noted. Thank you very much.
