- Jun 27, 2017
- 88
- 35
Hi, just purchased a 1.3 multijet 2003 Punto NON Air Con Model. This car is very easy to work on but I cant find a workshop manual for the diesel variant. I am trying to replace the cracked ribbed alternator drive belt. My model has NO AIR CON. I loosened the 15mm nut on what I believe to be the plastic tensioner wheel but the wheel does not move, does not look spring loaded and is solid. How do you release the tension on the ribbed belt so I can remove the belt. Kind Regards for any help.
