Hi guys this is my first post,hope someone can help me,
I have a bravo 1.6 dynamic multijet on 2008 plate with 38k miles.
The clutch biting point is quite low and grabs easily and is easy to stall from 1st gear when stationery but its fine in other gears.I have done the old trick of pulling away in third with handbrake on...car stalls so clutch is not slipping.
It doesn't seem to pull away smoothly as other cars i have owned,like my wifes 07 clio... Plus i have a small oil leak from under engine ( drop s visible on drive over night)not sure if clutch fluid or oil...need to check where leak is coming from plus there is a faint smell of oil/ lubricant inside car sometimes.
Read lots of different common faults of what it could be on t'internet not sure what it could be thanks
