FIAT Auto Specialist Team
Thread Tools
Old 27-02-2017   #1
New and need advice
Hi, I have recently brought a 2002 fiat punto mrk 2 as a project car and was wondering how easy it would be to swap the current 1.2 engine out and put the punto 1.8 engine in? would this be an easy fit or would it require alot of fabricating?
Thanks in advance
MrMagic98 is offline Reply With Quote Quote
Old 27-02-2017   #2
flisko has donated!
Re: New and need advice
not easy, cheaper and safer to buy hgt than to start swapping parts over
flisko is offline Reply With Quote Quote
Old 28-02-2017   #3
Quote Originally Posted by flisko View Post
Okay Thank you, so i should buy a hgt engine and put that in instead?
Thanks Alot
Old 28-02-2017   #4
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
If you modify your car your insurance will be far higher than just going and buying a 1.8 that left the factory as Fiat intended.
D
Old 28-02-2017   #5
Quote Originally Posted by rallycinq View Post
D
Hi, yes i understand the insurance price but this does not concern me i just wanted to know how hard it would be? thanks
Old 28-02-2017   #6
Charlieboy13 has donated!
As above, really not worth the hassle. You can pick up hgts cheap enough as it is.
If you're gonna do an engine swap might as well put 20vt in there or tjet for the hassle and cost.
Charlieboy13 is offline Reply With Quote Quote
Old 28-02-2017   #7
brinker has donated!
Denmark
It's not just the engine.. You need front/rear brakes as well as full front suspension (as it's different to cope with the higher weight).
Personal Best Lap Times:
Circuit Park Zandvoort - 2:37.89 (Fat Amy @65BHP)
brinker is offline Reply With Quote Quote
Old 01-03-2017   #8
Ireland
sadly im with the lads on this one.
alot easier to sell your own,and buy a factory built punto hgt 1.8.
the hassle of getting a 1.8 engine,ecu,coded key from donor car that engine came from,gearbox change,another rad needed ,wiring loom etc.
and then you have to beef up the brakes,front and rear,stiffer springs to cope with new engine.
you would have to buy a hgt to do the conversion
best buy a hgt 1.8,or buy a modified punto to a higher spec like a 20v.
but make sure its been done to a good standard and passes mot's/sva test.
alot of 'freds with sheds' death traps built in back gardens.
best of luck with your project what ever it ends up being
irishcento is offline Reply With Quote Quote
Old 01-03-2017   #9
Quote Originally Posted by irishcento View Post
Thank you all for you advice, I have done a little more research and am going to either go with a fiesta ecoboost engine, or a fiesta 1.6 st engine depending on what fits in my engine bay. For the brakes and suspension I have already taken this into consideration and have brought brembo high performance breaks and am in the process of getting some coil overs for the suspension also thinking wheel spacers but will need to measure the wheel arches for clearance etc (may need rolling).
Old 01-03-2017   #10
varesecrazy has donated!
Quote Originally Posted by MrMagic98 View Post
out of interest are you using a plug+play loom..
as the mk2 is a PIA for weird canbus stuff..
Old 01-03-2017   #11
Ireland
ah all info we wernt given in the first post
we thought you were a newbie thinking a engine swap was easy.
your a pro at engine swaps and setting up cars to high spec.
good to see your pushing the boundrys of the humble punto.
i look forward to your posts and the work involved.
not in a bad way to us fiat owners,but why a punto as a base car??
if i was going that mad and exspence id be modding a pug 205 or k1 vw gti etc.
but hay what ever works for you.
Thread Tools
(G) First Panda 4x4 buying advice needed, newbie advice needed!! BenMK4x4 Panda (Classic) 19 04-06-2009 20:33
(T) Mk2 Punto ECU + Lock fitting advice? advice needed jaynlisa08 Punto (Mk2/2b) 12 13-01-2009 20:19
(S) hi im new advice please. Smally Grande Punto 4 20-07-2007 00:31
(G) PX Advice please 1.2LStilo Stilo 4 21-06-2007 18:18
Some advice please? Tony Clarke FIAT Boo Archives 7 04-11-2002 00:42
