Punto (Mk2/2b) cylinder head
keith kkk
I want to change my cylinder head on my punto active 1,2 8 valve. I have looked on many sites and they all ask for my cast number. I give this and they say nothing in stock to match this number. dose this mean I cant put a head on with out having the same cast number. its a recon head I am after. Nothing wrong with my head I was going to have it terror cleaned but I think a recon head will be better. any advice welcome thanks...
I'll say it again. "If it's not broke don't fix it" Why go to all that bother when there is no need unless you have diagnosed a problem with the cylinder head. Do you actually have a problem with it? Why are you so keen on a terra clean? It's only a 1.2 and they don't have startling performance so keep your money is my advice. Different if you have a particular problem so let us know what the problem is if there is one.
only little problem is spark plug no 3 crossed threaded apart from that nothing wrong. thanks for your input...
If the thread isn't too bad you could use an expandable thread restorer, Works from the inside out) if it's bad, a helicoil.
