Hello everyone , my name is " Zake ," and I live in Brazil , where I work in a mechanical workshop.
A few days ago in did a repair on an engine of a marea 1.8 16v , those known as " HGT " , and during the assembly process , everything went well .. until the first match of the car.
First we had a small leak of water fluid the water reservoir cover, replaced it with a new, the problem persisted after that we were looking for parts that have not been replaced in the repair , which was the case of the radiator , we removed it thinking I would be blocked and sent for repair.
But the problem persisted and we realized that the radiator is hot on one side and cold on the other, causing the swarm of top water stick with too much pressure, while the bottom not even heats up, thus causing the super car heater.
I wonder if any of you already had a similar problem , and if they could help me , thank you very much and apologize for anything wrong writing, did the text by the translator.
