Ducato Ducato 53plate front cab doors and side door won't open
Hi my side door and cab doors won't lock or open with my key has anyone any info or advise on this please
If key doesn't turn and theres no external sign of damage key / tumblers may be worn, you can remove the barrel and file the tumblers. If it does turn the rod inthe dor may have come off or need bending / adjusting. IF theres any sign of extrnal damage you've probably had a chav stick a screwdriver it in.
If you're talking central locking the slidign door contact is made out of rubbish and tprobably rusted away onthe door side, its at the bottom rear side of the door near the rail.
Corcai, do you do any diagnostics? I did PM you but no answer.
Didn't get a pm, i see theres a visitor message now though. I'm in Cork City if you need it plugged in ask Pat Horan they have the same gear I do.
