Thread Tools
Old 17-03-2016   #1
Heater and speedometer problems
Hi everyone , here is the 2 issues I have, my heater don't work on any setting, I followed the instructions of everyone's
Replays in the forums, I replaced the resistor under the glove box, but unfortunately it has not worked , I don't know what to do now, the speedometer problem is it don't work, all the other clocks work fine , just the speedo has stopped for some strange reason , is there a fuse I need to look for , that goes for the heater to, thank you everyone for your help , I really appreciate it , regards Connor
Connorsky64 is offline Reply With Quote Quote
Old 17-03-2016   #2
varesecrazy has donated!
Quote Originally Posted by Connorsky64 View Post
Hi. Remove fan motor. Check it works. Then check for 12 volts at the power lead plug.
Speedo has a sensor on top of gearbox
Old 17-03-2016   #3
Re: Heater and speedometer problems
Thanks for getting back to me varesecrazy, can you tell me were the fan motor is ,
Do I need to take the dash board out , regards connor
Old 18-03-2016   #4
Usually a case of looking UP from passenger footwell
The guide at top of FAQ s .. GrandePunto section will be a good start.
Charlie
Old 18-03-2016   #5
Thanks Charlie, I will have a look at it , also I checked the sensor on the gear box everything looked ok
I have no idea how to test if the sensor works or not , in your opinion could the speedometer part of the clock be knackered , should I buy new clocks ,thanks for your help connor
Old 18-03-2016   #6
Hi again,
chances are you can check for voltage in the sender on gearbox,
not something I've needed to do..,
anything else not working..you may have lost an earth connection..or even a fuse
if you connect to the OBD port.. maybe you can see if the speedo / odo is connected still
Old 18-03-2016   #7
Sorry Charlie , I am really thick when it comes to vehicles, I no nothing about them or were anything is on them, can you tell me what the obd is and we're to find it , also what do I connect to it , sorry to be a pain ,
Regards Connor
Old 18-03-2016   #8
Regards Connor
look in the Doblo section - bottom of homepage
normally a socket at fusebox next to drivers knee,
Charlie - Oxford
Old 24-03-2016   #9
When the speedo stopped on my 2004JTD ( the day before the MOT) I disconnected the battery and left it disconnected for a few mins, the ECU reset its self and the speedo came back to life.
piratepaul is offline Reply With Quote Quote
Thread Tools
(T) Speedometer & Milometer Problems La Volpe Punto (Mk2/2b) 19 10-07-2014 13:54
seicento speedometer problems danielscott Lets Talk FIAT 2 30-11-2009 21:41
(T) Gears, Speedometer and major problems.... appaz88 Punto (Mk2/2b) 3 13-10-2009 14:37
(T) Help please. Speedometer & Rev Counter problems with my Ulysse ratboy125 Ulysse 1 20-08-2009 15:12
(G) Speedometer and Starter Motor Problems MikeSalt Punto (Mk2/2b) 4 11-07-2008 09:41
