Croma Gearbox
Croma Gearbox
johndavidneville
johndavidneville: Hello I need help been trying to fin d a gearbox for my fiat croma 2006 5speed petrol manual gearbox(17:08)
johndavidneville: Has anyone fitted a vauxhall/saab gearbox to their croma ? I had a message back from a breaker yard he wanted £700 for a gearbox straight from a car, he said oh yes wish i had 20 of these boxes i could sell them all, these croma grearboxes go all the time i think he was taling the P**s(17:11
Hi, :)
why is this in the "Newbie Section":confused:
what is actually wrong with yours..??,
there are a few good refurbishers listed on the forum now..,
Charlie - Oxford
Hi, :)
Charlie - Oxford
Hi sorry have trouble finding my way around, my gearbox 5 gear no longer works wont stay in and now reverse is playing up, ive had it repaired once but the guy botched it, only way now is to replace it, can a vauxhall gearbox be fitted, dont want to pay a thousand pounds having a recon or mine taken out and repaired again
Hi just read of your gearbox trouble,I would think that as Fiat fitted a lot of GM parts that your gearbox is probably iether a F17 for a 1.8 or F23 for a 2.2 have look on ebay for one that was fitted to a Vectra Zafira or Signum :)
From my Technical Notes File
Fiat Croma 1.9 8V & 16V MJET gearbox is a GM M32WR Type 1 with final drive ratio of 3.650
Data taken from Croma eLearn CD
Gear Ratios:
1st: 3.818
2nd: 2.053
3rd: 1.302
4th: 0.959
5th: 0.744
6th: 0.614
Rev: 3.545
Final Drive: 3.650
Weight: 41.5kg
Oil Capacity: 2.4 litres
Oil Type: SAE 75W-85 API GL4
Vauxhall/GM Vehicles using this exact same gearbox are: (Model & Engine)
ASTRA H:
Z17DTH
A/Z17DTJ
A/Z17DTR
Z22YH
ASTRA J:
A17DTJ
A17DTR
MERVIA A:
A17DTJ
A17DTR
SIGNUM, VECTRA C:
Z19DT
Z19DTL
ZAFIRA B:
A/Z17DTJ
A/Z17DTR
Z19DT
Z19DTL
Hope this helps in finding your gearbox.
looks as if it IS an M32 gearbox you need, :)
thanks to S130:worship:
gearbox is common to the Grande Punto 1.9's - but I was not so sure in the Croma:eek:
This car is the sum of GM+FIAT (+OTHERS as all modern cars in the world) parts and the manual gearbox is GM....I know of other persons who had problems with it.
Ironically the Croma automatic gearbox (AISIN WARNER), as I have been testing, is infinitely more resistant (405.000 km till now)
