Punto (Mk2/2b) Thermostat
Dave548
Hi Guys
Well, a few weeks ago I picked up a lovely little Punto 1.2 16v on a 02 plate.
74,000 on the clock and am now trying to iron out those silly little problems.
To start, when I bought the car it was only firing on 3 cylinders, a quick check of the HT leads indicated a totally duff lead. One new set of HT leads and it seems to be running fairly well, averaging around 42 mpg.
The next prob seems to be the thermostat but would welcome your input!
Whilst driving the temperature gauge is up and down all the time. With the heating turned up and the blower fan on it cools right down.
1. Am I right in thinking the thermostat is stuck open?
2. Would this cause the engine management light to stay on (diagnostics gave an unspecified fault code 113560?
3. Would this cause the engine to be sluggish when pulling off?
4. How easy is the thermostat change/bleeding the system etc.
Look forward to your input. Thanx
Stuck open 'stat you would see temp gauge cool all the time. Fluctuating would suggest sensor, or possibly low coolant. Changing 'stat is straight forward - did mine last weekend. It was stuck open, never got more than 1/4 up the gauge. Now within a mile its sitting at 90.
are you saying your car warms up to temp and gauge on middle in 1 mile from cold?
there are alot of punto stat's that go duff quick
the classis fault is - the engine gets warmed up, no problem, stick some heaters on and then come to some lights - the guage shows a decrease
Start driving again and it starts to work its way back up
You find it takes alot longer then normal to warm up
I could get to work 5miles away and it'd only just get to middle
With new stat fitted it took 2 miles
Dont go white box special
Get a genuine one - i've no issues with my genuine one since fitting it
Its also worth noting, that air in the cooling system is a bitch
getting it out - is a bitch
But a good bleed should help cure it
Ziggy
Thanks guys appreciated, any idea if that fault code could be connected with this?
Ziggy
hi, sorry to trouble you, my daughters fiat punto , seems to get very hot, and she said it was making a strange noise , ive told her not to use it as i think it could be the thermostat stuck shut/open but for the life of me i cant find it on the car, its a fiat punto activ 1.2 can any one give me step by step instructions and how to recognize it and where it is
https://www.fiatforum.com/punto-mk2-2b-guides/348260-thermostat-change.html
paper gasket is not needed,just use gasket sealant
