Hi Alco, I assume you're referring to the plastic clip that goes through the window glass. It's attached to the regulator by a thin piece of plastic. Push the piece facing the skin of the door upwards from the bit that goes through the glass and it should then pull away from the glass. On mine the plastic was pretty brittle and snapped as I was doing it. Good luck.
Did you buy from Fiat and was it expensive?
