L Ldida New member Joined Aug 11, 2014 Messages 2 Points 2 Aug 11, 2014 #1 Hi can anyone tell me where the fuel cut off switch is located on a 2006 Fiat Doblo 1.3 multijet? Thanks
B Brummy Exile New member Joined Jul 3, 2012 Messages 57 Points 20 Aug 11, 2014 #2 On our 2008 1.4petrol, the cut off / reset is accessed through a hole in the trim below the A-pillar on the driver's side. Figure 94 on page 69 in the handbook if you have one.
Andoo Member Joined Apr 5, 2010 Messages 318 Points 76 Location Highlands Aug 12, 2014 #3 As above... Look near the throttle pedal, then look at the kick panel near the door (under the fuse box) and feel for a hole a little bigger than your finger. Poke it in there (ooerr ) and you should feel a rubber button. Push it till you feel/hear a click and that will reset it. They go off when hitting pot holes or kerbs pretty hard.
