I have a qubo less than 3years old which as a problem...
When I unlock the doors (off key fob) they will lock again straight away. This leads to a lot of fob pressing and door pulling before I can get in.
I've noticed this only happens when it is very cold (10 degrees or less or hot 20 degrees or higher) the higher / lower the temperature the quicker it takes to lock.
The garage say it is not a warranty issue so will not investigate or fix it.
Not sure if it is related but the only other issue the car has is if someone is in the front passengers seat it will flash up they haven't got their seat belt on when they have...but only once or twice in a journey not all the time.
Hope someone can help....
