Our 2009 Fiat 500 1.4 sport duelogic kept cutting out after initial start up in the winter of 2012 (it was a cold one!) and then driving to the end of the road say 100 yds just as pulling away would cut out again. Always started back up but a bit of a pain. It also on initial start up sounded as though the starter was jumping out and back into mesh with the ring gear. On it's annual service the mechanic told us that Fiat was now fitting a larger AH battery than the 40 AH originally fitted as this was probably the problem. Although the car was in it's third year the battery warranty was only two years!! We left it and touch wood has been ok. Yesterday we came to start it after a trip out and it was totally dead. Jump started it but driving back we had all sorts of warning lights coming on would not pull, missfired, gears went to nuetral etc etc. Managed to struggle home and switched it off - totally dead.
Going to replace the battery but does anyone know what AH battery fiat are fitting on the 1.4 500's to alleviate this problem and has anyone else had this fault????
