Thread Tools
Old 15-09-2012   #1
climate control berserk
Hi All, I have a Punto 1.9 diesel JTD Eleganza, which I bought s/h about 4 years ago. after a couple of months on sw on the "service expired" info would appear which was no problem. Since last january on sw on "glowplug failure" appears but disappears after 20 seconds- again no problem. In the last couple of days the climate control fan comes on then goes off then varies up and down very erratically. Its a digital display type of climate control. Even if someone could tell me how to get into it it would help. The digital display itself comes and goes as well. Any help please? Bachgen.
bachgen is offline Reply With Quote Quote
Old 15-09-2012   #2
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Re: climate control berserk
Sounds like an earthing issue or a power feed issue
Ensure all the earths are nice and clean
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 15-09-2012   #3
Welcome to the forum
Service warning required reset using something like Fiat ECU Scan but you need the full working version which is £50 plus all the cables (another £30-40)
the Glow plug light means one has died and probably killed/is killing all the other plug, this is because they are always wired in series and if one goes it takes the others out, a new set is probably about £50 just as a warning your car won't start as the colder mornings set in
The Climate control sounds like it could be an earthing issue although I would have suspected problems with other things like dash lights and switches not working or it could be a loose plug/wire, getting to it requires you to remove half the middle of the dash though. however you can accesses it with diagnostics (as mentioned above to reset the service light) which might give you some idea of whats going on.
I would have thought that if the climate control was completely losing power then it would cause a can-bus fault and your multifunction display between the speedo and the rev counter would start flashing.
what do you have the climate control set to? if its full auto then the computer will turn the fan up and down as required.
Maker and voice behind the YouTube channel PuntoHowTo 10k subscribers canít be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is offline Reply With Quote Quote
Thread Tools
(T) install Climate Control into non-climate model Panda hollister Panda 4 17-05-2012 16:18
(G) climate control mickbr71 Stilo 8 11-10-2009 12:12
(T) Climate control Q? juwel-180 Grande Punto 6 31-03-2008 01:48
